1 - 20 of 68 Posts
well its starting to look like a real bike now.probably one of the most corroded resurection bike iv seen on this forum.shep started,and ill finish.
waiting on wemoto for seals to rebuild the brake calipers,paint the tank,side panel etc.....nearly there........
if nothing else,its been a great learning curve
shep,im glad i bought that exhaust off you,it polished up nice.thanks
Wow bandit, that bike looks amazing. Especially considering what you started with.
thanks Subby,its been every nut,every washer needed work on.
ill fire it up next week,[or try to]hook it up to a temp tank.
when you see those photo,s shep.......it was all worthwhile.lmao.
am i allowed to post the emails where you called me all the bas££3ards under the sun.lol..
No.You are not even allowed to post the above and I didn't call you,"All the Barstewards" under the Sun,only most of them
Yet another twisted twin snatched from the clutches of death. Reminds me of one of my favorite Bible verses:
1 Corinthians 15:55 O death, where is thy sting? O grave, where is thy victory?
i think you know more bad words than me.lmao
Poor Sunflower. At least its deterioration is reversing.
poor sunflower....that is so sweet.
I only can wish I could do whats been done to "Sunflower". Great job!
Discussion Starter · #14 ·
had a spare bit of time this week.got the calipers sorted.
got to a stage,wanted to see if it would fire up.didnt want to refit everything,and then have to take it all off again.
connected up the battery,connected it up to a dummy tank a small squirt of brake cleaner into the airfilter and ignition,fired up first time.
painting the tank etc next,bleed the brakes and probably a bit of electric trouble shooting.
but,at least the engine sounds sweet.
i bodged up a video and sent the shep.ill try again momday.
Discussion Starter · #16 ·
Paint job's looking nice
Those brakes ok now?
thanks shep,better painting now the sun is a bit stronger.
the brakes are all connected with their relevant crush washers,but not tightened down,ill put some 8mm spacers between the pistons and bleed next week
ill let you know
Is that the basket case you picked up a while ago??
If so, post a before pic too, if it's the same "bike", there's no way to do justice to the transformation without a before picture.
If it is the same bike, you should change your status from "Grand Nagus" to "Lazarus" under your avatar.
Congrat's Bandit! That is one hell of a transformation! I bet you felt great when it started up.
1 - 20 of 68 Posts
