1 - 8 of 8 Posts
What length stainless brake line do I get from JDaent? The 39" or 41" also, WTF do I put on the front one?
1979 CX 500 Deluxe
can you explain a little more,you have a 79,
what does...........what do i put on the front one mean?
The front brake line? I'm kind of stuck 30 minutes away from the bike and haven't started working on it yet so I assume (yeah I know) that the front brake needs a line or am I wrong? I'm new to this stuff so be gentle.
Most definitely the front, the back is a drum brake actuated by a steel rod.
ah,i see,only one question.i read it as though there was two.
as Don said,40 inch is the correct size.even though i have twin disc,40 would be correct.
btw.no such thing as a stupid question
good luck
1979 CX 500 Deluxe
If your bike is stock just tell Craig the year and model as he has the lines all made up. If it has been modified then you need to know the length.
1 - 8 of 8 Posts
