I almost (finally) have everything I need to get this bike back on the road.
I want to put the pre-load spacer in the front forks. I figure while I am there I will change the fluid.
I will put 20 W in. How do you drain it?
Do you have to pull the fork to drain it or is there some obvious method I am missing?
Thanks!
Thanks!
i dont think your 78 comes with drain holes.so,if you are going to introduce a spacer on top of the springs,id slide the forks out,then drain upside down
You can also pull the wheel off and take the allan bolts out from the bottom that holds the forks together. Slide the lower down a bit and they will drain.
However, if the forks have not been done in a long time they should be separated so you can wash all the grunge out that settles in the bottom.
Changing the seals is always a good idea but may not be necessary if their in good shape. If you see any dry cracks in the seals or dust covers I would change the seals at the same time. Go with the Honda seals too. They work and last better.
Sounds like the forks will be coming of soon!
Thanks for the replies.
I think I will finish the engine first then pull the forks.
One project at a time.
I get confused too easily to have more than a couple open at once!
