I have been trying to replace my piston rings. Both heads are stuck on and I can’t seem to get them off. I don’t think I have any bolts left to take out. I have already removed the 4 head studs and two head bolts. What am I missing?
If you have a compressor and can weld you could do what I do to remove stuck on heads.
I set the motor to TDC on the compression stroke and fit a tool made from an old spark plug, a piece of steel tube and a fitting to fit the compressor hose.
I put the bolts back in about 8 - 10 turns undone and then use the tool to blow the head off. The bolts refitted prevent it hitting you or the floor.
Remove spark plug, roll engine so that 1 piston is at BDC, bottom of stroke. Feed a large amount of rope into the cylinder through the spark plug hole, rotate motor and the piston and rope shoule push the head off, if the motor is not stuck.
