Triple Bypass Procedure....Slowly but surely I'm getting to the Stator...but I'm pulling everything off to have a good look.
Of question is the connection for the tachometer. The bolt at the bottom has been soaking in penetrating oil for 5 days. Finally it's out. There was heavy corrosion on the bolt halfway up the threads - right to the non-threaded portion. The very end tip of the bolt where the thread begins was stunningly clean. You can see from the pic below there is corrosion inside the bottom bolt hole. All other's are pretty clean - super clean in fact. Why would this one bolt have corrosion? Any thoughts?
Also, I'm unable to get the tachometer connection off. It wiggles about an 1/8" clockwise and counter clockwise, but I can't remove it. Any thoughts?
Please ignore the amount of oil you see on the engine. It's simply the overspray from the penetrating oil.
