21 - 22 of 22 Posts
Add an electric heat gun to the list, did I miss it above? It works very good on the tiny little cover bolts, so you don’t end up with needless/extra work.
Discussion Starter #22
Ok, I managed to get the front cover off and check the oil pump.
The pickup filter had a load of junk sitting there, a few silver specs, some magnetic, lots of black bits of gasket material (I assume).
Thankfully, no copper bits.
I've taken the pump apart and the internal gap is within spec , I can get 0.08mm through but 0.10mm is too large.
What are peoples thoughts on the pics attached? The bike has about 40k miles. I cannot really feel any of those marks.
Thanks!
21 - 22 of 22 Posts
