1 - 2 of 2 Posts
I need to drip and detail clean my right cylinder head. Other than the valve removal tool, any suggestions on what I can use to remove and reinstall the valves?
Use the correct tool.Removing valves is a very dangerous procedure even with the correct tool.Always face the head down and away when releasing the Valve springs or re-fitting.There's enough power stored in the compressed springs to injure if not kill.
Also read the manual for the correct re-fit procedure and tapping the valves with a rubber mallet to check the seating of the collets.
http://cgi.ebay.com/ebaymotors/8-IN...Z360363200235QQptZMotorsQ5fAutomotiveQ5fTools
or see if you can borrow one.
1 - 2 of 2 Posts
