I think what you are seeing is a normal wear pattern. The 'front' of the individual tread hits first, and as a result will wear at a different rate then the rear - look at your own running shoes and you'll even see this in the wear pattern on the soles.
Left to right differences is caused by the crown of the road. All roads are designed to allow water to flow off them equally left and right. This crown will also affect the tread pattern.
One other issue, and this was discussed before, is that in North America when we turn left, it's usually a wide long turn, but turning right will be more 90 degree and quicker. In the UK they notices exactly the opposite - with long slow turns to the right and short quick turns to the left - as they drive on the 'other' side of the road. Either way, affecting the tread wear pattern differences left to right.
Check your alignments - sure, but on a bike if you're riding straight, it's likely to be good. It looks like you got use of the old tire, and it's time has come.
