I cleaned a carb using the Simple Green in an ultrasonic cleaner then followed that with carb cleaner from a spray can. The piston, top and spring seemed pretty clean.
But after being pushed down into the top, the piston would only slowly rise and take like 10 seconds to rise completely out of the top.
For some unknown reason, maybe through manually moving it up and down, the piston began to move more freely but is still a bit sticky when pushed into the top. It slides through the carb body with no problem. Is there something I can do to make it move more smoothly? Thanks.
