1981 Honda CX500 Custom
So I did the stator tests for vAC and for resistance. Here are the results.
White Wire circuit ~80 vAC
Blue Wire circuit ~93 vAC
Resistance Tests
Blue-White ~ 78 Ohms
Green-White ~350 Ohms
Blue-Green ~428 Ohms
Just want some confirmation that all these values seem acceptable and are indicative of a proper functioning stator. The battery is new and seems to be getting properly charged from running the bike.
I did these tests because there is a strange throttle deadzone bog down in every gear somewhere between 4K-6K. It seems like I have to hold the throttle at just the right spot to accelerate through that rpm range but the bike will indeed run above 6K. Something I discovered yesterday is that there is NO air filter inside the air box and I was wondering if that would allow the bike to get too much air at once and perhaps bogging it down. Just tracking down my "go gremlins" so I can get this baby running well. Thanks much!
Cale
Resistance Tests
Cale
