1 - 20 of 24 Posts
Discussion Starter #9
Ok thanks a lot!
I'm quite hesitant about buying a new stator due to the cost, do you think it's worth trying to fix the wiring harness if any wires have been split or should I just bite the bullet and get the new stator?
If the stator is black or close to it I would just replace it. { they start out a reddish/brownish toffee colour} If considering keeping it run through this. Hell, run through it anyway. there's components there you'll be keeping regardless and if iffy are best replaced while you have the motor open.
Discussion Starter #11
F*ck it, I've just ordered one. Triple bypasses are expensive work.
I've been told to change the camshaft oil seals, they sell a front and rear seal. Are both important to replace?
You won't need to replace the front seal as part of this job but if you choose to it is 17 x 28 x 6 or 7 (either thickness will work} and the rear that you WILL want to change is 18 x 28 x 6 or 7. You can buy these sizes at a bearing shop and save a few pound.
Discussion Starter #13
I've ordered one from David Silver Spares along with the Stator.
My list of parts are now:
Gaskets
Clutch plate kit
Cam chain guide
Cam chain
Mechanical water pump seal
Stator
Rear camshaft oil seal
Hopefully this list won't grow any more :serious:
1 - 20 of 24 Posts
