I’m in the process of switching my stator. I have a grounding question. I’m installing a TI stator in my 81 CX500C. I removed the advanced pulser coils from the engine cover. I’m going to ground the stator in one of these screw holes. Do I need to have an additional ground wire come from here and ground to the frame of the bike or the battery? I also have an Ignintech installed.
Thanks in advance,
Mark
The engine should give a good ground by its contact with the frame
so you dont have to have a ground cable with a TI stator
Its more of a belt and braces thing.
The stator itself needs no grounding.
You can leave those wires there. It won't hurt anything. I usually put the stator ground wire where the screws held in the pulsar assembly just for added insurance. But either way is fine.
If you're fitting a TI type stator I'd suggest a trial fit to check there's no chafing
of the windings on the rear cover.
It wont take long and is worth checking, just in case.
Also test the L&R pulser resistances are well within spec, if you have
any doubts about them nows the time to sort it.
the advance coils are redundant with a TI stator so do what you like with
the wires.
Personally I'd remove them for neatness but its not a crucial decision.
Adding a secondary or backup ground wire as Larry has will do no harm and
should the motor to frame contact be compromised it wlll help to keep
all grounds at the same potential.
I had an issue when my top engime mounts worked loose which gave some odd
ignition problems until I found and fixed it.
As I said, belt and braces
Hope it all goes well
