Hi,
I am new to the forum, I got a 1980 CX500 a couple of year ago, It was running perfectly until last week. I was going to work and the bike suddenly lost power and stop. I recharge the battery and change the spark plugs. Then it happened again. I did the test and looks like my stator is failing.
I tested all the circuits, everything checked out except 9/5, which was 30 under the limit. I was looking for solutions in the forum and found a thread from 2016.
www.cx500forum.com
I've found two options so far (please enlighten me if there are others). Replace stator or replace the stock CDI with Ignitech.
I would like to avoid taking the engine. Is there any other new solution since the threat is from 2016?
Thanks for your help.
AJ
Stator failing..seeking advice. Replace cdi with...
Stator failing..seeking advice. Triple bypass questions. CDI/Ignitec Stator Cam Chain Hello, Forum lurker, first time poster. I've got an '81 CX500 Custom with roughly 40K miles. I've been running into a barrage of issues with the bike recently. Many problems solved thanks to this forum, thank...
AJ
