I have a feeling somebody will know right away.
I have one of those LED headlights with built in running light and turn signals but I decided to to add bar end turn signals / running lights. Anyways, I got the bar end lights working just fine but now all of a sudden the headlight (both low and high beam) is not working.
This seems like an interesting problem but probably an easy fix. So, when testing the turn signals (I cannot recall which side) but suddenly the starter clicked on for a second! I tested each side for the turn signals maybe 10 times again and it probably happened again once (10%) of the time.
I am guessing that once I figure out why the headlights (low beam and high beam) will not turn on, I will probably solve the issue with the starter being tripped. I am thinking it must be something with the starter button which I admit has an issue anyways. When I push down the start button, I cannot push it all the way down. I have to push it like 1/2 or 3/4 of the way down and it works or else if I push it all the way down it does not work.
