Well I took the bike out today and the ride was short, maybe 30 minutes? I went to pick up some resistive plugs after doing the Brass Rod Mod to the Plug Caps. Currently I am still running the standard 8KEA plugs, picked up Champions version of the 8RKEA's and I have yet to install them.
Note that the bike started to hiccup when riding prior to doing the Brass Rod Mod.
When I got to the parts store I rolled up and the idle slowly dropped and stalled in the time it took me to find neutral to park it. It started but needed coaxing from the throttle to stay running--hand off the throttle, RPM's drop and she would stall. Every light needed some throttle to keep the motor going.
Acceleration is skittish anywhere even after 4K and 5K...when you get above 6 and 7K it seems to go, but not like I remember it did.
I checked the temps with the infrared gun, and the right side head just above the intake was 190F and the right side was around 178F.
It was cooler than usual this morning, but the temperature gauge found the middle, and then dropped back and never got to the middle again, and hung at about 75% of the thin-lined low zone.
I just got in and have not checked some of the more obvious things like replacing the fuel filter, checking the carbs to ensure they are clean (I did rebuild them the Cargill way) float levels etc.
I have my road test on the 25th of this month and would like to sort it out before then!!
I've read up a little by searching for my 'symptoms' and I think I am heading down the path of diagnosing the coils, CDI Unit, Pulsor, or Stator. What do you all think this sounds like? I am not too smart with electrical, but if I have the info I have a nice multimeter and should be able to trouble shoot the obvious if given some proper instruction.
thansk guys!
thansk guys!
