Hey everyone! I’m 23 and my 1979 cx500D is my first bike so I don’t have much experience with diagnosing mechanical issues. However I did rebuild the left head a month ago because I broke off an exhaust stud trying to replace the rear crank case cover.
When I had it apart I didn’t mess with any settings on the carbs or anything.
It’s always had a throttle issue, I have to baby it really slowly from 1k RPM to 5k or it’ll bog down and have no acceleration but takes off after 5k.
After I rebuilt, it ran on first start and idled fine, rode just like before but a day ago just started dying almost every time I roll to a stop unless I pull the choke fast. It has also been backfiring a lot.
I’m also trying to replace the turn signal/horn switches with one I bought off Amazon so half of those wires have been cut and are hanging cause it’s very confusing to me.
Right now I just want to figure out why it keeps dying.
This sounds like a failing low speed coil in the stator. Measure the resistances as shown here.
Where are you, Matt? If you happen to be in the Twin Cities area, I can help you out.
By the way, you shouldn't have cut any wires. All that stuff unplugs.
I don't have answers for your current issues but welcome to the forum. Please add your location and your bike's model and model year to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
