Well, finished my major overhaul on the engine, cleaned the oil pump and tightened chain, tripple bypass and new oil seal, and starter motor rebuild. Put it all back together and all moved/worked well. Put it on the bike and started testing it out. Filled the fluids and squirted some oil in each cylinder, then turned it over by hand using crank bolt for a few dozen revolutions. Cranked the engine with the plugs out and all worked well, so I cranked it for about 3 seconds at a time until I saw the oil light go out. Put the plugs in and again cranked it (kill switch) and sounded good, cranked fast and oil light went out while cranking .... well, looks ok so far.
Put the tank on and hooked it up, open petcock and put choke on. cranked twice and it sputtered a bit and started right up, shut it down after 35 seconds (no exhaust). Put the exhaust on and started it up with the rad cap off, ran VERY smooth and didnt need chock after about a min. Warmed it up to operating temp and watched the fan come on once it just passed the thin/thick line by about 1/4".
So far all seems really good, so put it together and threw the seat on and went about 1 mile to Crappy tire to buy a push in fuse holder for the fan (replacing round one under seat and putting a push in one where the tool kit must have gone behind right side cover). During the ride the bike was vibrating to the point I was worried. To me it "felt" like somthing shaking .... actually like the crank shaking. The engine stayed at the thick/thin line all the way there and back with the fan rarely comming on (and its hot here today). I found the heads very hot but within normal temp according to the heat gun and guage.
After doing the fuse I started it again and let it warm up and run for about 1/2 hour. It sounds fine I guess (remember, this is the first time I have had working mufflers on the bike), sort of like a sewing machine on some super steriods. I decided to go for a short ride and see whats what. Seemed fine, and since I was alone on the road I opened it up to see if it would go "BANG!" I noticed that bike doesnt bog down anywhere near where it did before the repairs, and will accelerate fast out of a 40KPH ride in 5th. Took here about 2 miles at 60 KPH, temp normal, but the shaking/vibration seems to be when Im getting close to the shift RMP (I have no tach so no idea what RPM it is). On the way back I went down an open stretch (limit 80KPH) and without opening up fully, I cranked it most of the way open and the bike shot off really good. Before I knew it things were a bit blurry so I checked the speedo....pinned at 80MPH and going strong....slowed back down as it wasnt my intention to go that fast. Got it home and temp was fine and it sounded fine, just not how I remember it sounding.
So, am I being paranoid here. I know the bike did vibrate when I got it (not a wabble, just vibration like a massage chair on steraoids) but dont seem to remember it being this noticeable (although been a while since I rode it). I am sure if I had a bearing problem the engine would be dead already. So, can anyone think of anything I could have messed up in the bypass to give me this sensation of a crank flopping all over the place. Even checked the cam for rubbing on the fan ... nope, over 1/2 clearance. Not the valves or any loose bits. I need to find someone with a vid camera to see if anyones good ears can spot something.
Thanks all, it may just be my paranoia here, but the bike seems like its performing too good (especially since I know its running rich).
