1 - 7 of 7 Posts
after being hit by a truck a couple weeks ago ive decided to do a few modifications... since its either that or replace with stock. one of the mods i want to do is new mini tach/speedo. does anyone know what the drive ratio is for these bikes? btw its my 82 gl500
thanks -sam
Speedo/Tach ratios
Most vintage hondas have the same tach and speedometer ratiso. Speedo ratio is 2240=60mph. Tach is 1:4.
Before going all in maybe you should look at an acewell unit.
blind you are correct the speedo is 1:4 they are one and the same with the tach
Well yeah it changes but not really. It would still be 2240=60mph=96.5kph
The tach would stay the same.
The danmoto unit is a bit cheaper than the acewell. I don't have experience with either, but it may be worth it to look at it...
ebay link $125 shipped to US
danmoto international site - $89 + shipping (for some reason this is the cheapest route, even the US page is more expensive... Probably customs fees or something id guess?
Also, the acewell has a mounting kit/pod I believe. The danmoto would require some fabrication I suppose.
Has anyone tried this? I remember buying a gear indicator and I had to do the same magnet way to calculate the gears.. never worked properly unfortunately... not sure with something like this tho...
1 - 7 of 7 Posts
