On a friend's CX 500 I was supposed to replace the tachometer cable and rebuild the electrical system under the fairing.
With this in mind, we decided to mount the instruments away from the handlebars in the fairing, because that allows better routing of the wiring harness and also the speedometer and tachometer shafts don't hit anymore the fairing bracket when the handlebars are turned.
Since the speedometer was defective, Marko decided on a mini speedometer from the accessories.
...And because Marko, like me, has a weakness for aviation, esspecially for the Lockkheed F-104 Starfighter, I came up with the idea of designing the instrument panel and the instruments in "aircraft style".
With cardboard I made a first template for the "cockpit".
But before I make the panel out of sheet metal, I want to get the instruments and the other "fittings" ready first so we can do the positioning
and optimize the layout.
I measured the instruments and made a pencil sketch. According to this sketch, I turned two screens that sit over the instruments from above and, like an aircraft instrument, are fastened to the panel with 4 screws.
The whole thing still looks a bit bulky, but that will change soon.
I kept the rubber seal of the rev counter so that the tachometer is decoupled from the panel and stored with little vibration.
The speedometer has O-rings underneath it for decoupling, which are embedded in the cover
