After discovering the resistors in the boots were toasted, I picked up some brass rod yesterday. Pulled everything apart today, cut the brass to compensate for removal of the resistor, checked out every piece separately using a multimeter and every piece separately read 0 ohms (though the boots did give me a bit of an issue, but got them cleaned). Here is the issue, when I put it all together my resistance is now maxed out. Pulled everything apart, rechecked all pieces separately, which tested good. Did some isolation and it appears that when using the springs, the spring is not making good contact inside the assembly (springs tested fine, and I cleaned them up anyway to make sure). I am thinking that there may be too much corrosion deep inside the boot itself that is not allowing the spring to make good contact. Has anybody else seen this issue.
Fiddled around and got one of the assemblies to ohm out fine, but the other is not going to work. Threw them back on the bike, and after having to shoot some (ok, alot) carb cleaner into the fuel line, she did fire up and ran pretty good. My popping has diminished. Rode her for about 10 miles with no issues.
