So... after finally getting my '82 GL500i back on the road, I've been slowly taking care of the malfunctions that come with running a 40 year old bike with unknown maintenance history, and... I've hit a slight bump.
The bike runs... ~90% fine. I've put a few hundred miles on it already and it hasn't croaked, which is probably more of a testament to Honda's engineers than my own developing skills. It runs a bit rougher than I feel like it should be, and I lost spark to the right cylinder the other day while cruising down the highway. It kept chugging along on one cylinder until I hit a hill, at which time I shifted down to fourth and revved the engine... and then spark came back and it's been... adequate... since then.
I could be wrong, but I feel like after replacing the alternator, battery, and timing system, the only things left are the coils and plugs. I haven't gotten around to checking resistances on the coils, but... that's not what actually brought me here.
My Haynes manual recommends NGK DR8ES-L plugs for my model, and that's what I've been using since I first got the bike. The thing is... my spark plug caps still have their resistors. MotoFaction recommends DR8ES-L plugs for spark plug caps without resistors.
The bike runs, obviously. But my knowledge and experience with ignition systems is... rudimentary, so I wanted to get a second opinion with more experience before I start buying more parts.
How bad is it that I'm running resistor plugs with resistor caps? Irrelevant? 'I'm torturing my coils every time I run the engine'?
Also, while we're on the subject, has anyone else completely replaced a TI ignition system with aftermarket parts? Is it better/ worse, or can't tell the difference?
Better yet, has anyone put a few tens of thousands of miles on aftermarket ignitions? I intend to keep putting miles on this bike, and I'd rather not be replacing coils and spark plugs at the same time.
Any wisdom is appreciated. Thanks in advance,
Sam
Sam
