I think there's a 30amp fuse in the box and i'd keep it if if i were you.
Maybe you could splice the wire and relocate the box.
They make those aftermarket switches for the CX500C and I was wondering if that replaced that whole red wire and box. There is no spot for a fuse on the box In the picture I provided. I wonder if that wire off the box runs to the fuse box. Thanks for help I appreciate it, I will have to do some more research.An after market solenoid may have the fuse built in as part of the unit. This one for example. https://www.amazon.com/Starter-Solenoid-Silver-1981-1982-1983-1986/dp/B06Y2GR19K
I have no experience with this particular unit, it just showed up in a web search.
Yours has a the fuse holder as shown in post #6. Your picture in the first post shows the back side of the fuse holder.Mine doesn't have a fuse? Is there supposed to be a fuse on it?
The red wire is what supplies power to the rest of the wiring harness. You need it.... what about the red wire attached from the workng harness, can I eliminate that if I hooked this one up?
