1 - 2 of 2 Posts
1983 Honda GL650I Silver Wing Interstates (1 Red, 1 Gray)
SOLD 3/27/23
I’m selling one of the two 1983 GL650Is I’m restoring. This one is Nimbus Gray and was a 1-owner bike when I bought it to restore just about a year ago. I have a copy of the original owner’s title and his original bill of sale from the dealer! I also have many of the original owner’s service records. Rare to find a 40 year old 1-owner bike!
Current mileage: 31,029 miles. Bike rides and handles great. Engine and transmission function perfectly. Riding season is already here in the south! It’s ready to ride!
Tire Wheel Fuel tank Vehicle Automotive fuel system
Tire Wheel Land vehicle Vehicle Fuel tank
Tire Wheel Fuel tank Land vehicle Vehicle
New Dunlop D404 tires. New Yuasa AGM battery. New stock Honda handlebar grips. New Vista Cruise throttle lock. New air filter. Engine oil and filter changed. Gear oil changed. Lubricated rear drive gears with moly 60 paste. Lubricated pinion gear at zerk fitting with lithium grease. Coolant system flushed and refilled. Replacement Honda front disc brake calipers completely rebuilt with BrakeCrafters rebuild kits including new pistons. New EBC brake pads. New Galfer stainless steel brake lines installed. Front brake master cylinder rebuilt with BrakeCrafters rebuild kit and new fluid reservoir and cap. Rear drum brake removed, inspected, and cleaned. Brake pads measure 4mm. Right side front wheel bearing was clicking so I replaced both front wheel bearings. Installed new carb drain hoses and gas tank petcock drain hose. Installed new turn signal flasher relay. Replaced one bad side cover with a better one from eBay. About $700 worth of new parts and restoration supplies.
Gas tank had been previously repaired (properly welded) at bottom rear left edge. That small area is currently primed and will need the decal painted back on. (Shown in pictures.) Gas tank is sealed and has no leaks. Oil filter cover and clutch cover were badly pitted. Vapor honed both, then polished and resealed with clearcoat. Spent many hours at general clean up and detailing. Exhaust is near perfect except for one spot where some battery acid leaked onto the mufflers and discolored it a bit. (Shown in pictures.) About 90 hours of labor recorded in my daily restoration workbook.
Converts from a 2-seater to a 1-seater! Includes passenger seat, trunk relocation mounting rack, tool kit, and owner’s manual. All luggage and locks work.
I have a set of original Honda speakers that are not yet mounted, plus a set of original fairing panel meters for a Honda Type I stereo. This is the type without an intercom. These items go with the bike only IF you want them.
I also have a color matching 1983 Gold Wing trunk and mounting kit I made for it almost assembled. I will sell that separately IF you want it. (I paid $300 for the parts for that.)
Selling for what I’ve got into it: $3,250.00. (Bike is located near Greenville, SC.)
40 more pictures available in my Google Photos album, here:
40 Pictures of Bike
Pictures of just some of the restoration work here:
Some restoration pics
PS) Someone please let me know if these links are working properly, meaning I’ve correctly set the sharing properties to “everyone”.
1 - 2 of 2 Posts
