(late night edit!)If anyone could tell me if out ignition switches interchange with another bike(the GL's look the same?)please let me know. Mine is shot and in need of replacement. If that doesn't work out, is there some cliffsnotes on what goes where to by pass it? Dang it, i'm going to enjoy the fall one way or another...
Bike went down in the driveway. Bars, front signals and whatnot are being replaced. I've decided to go that race-y feeling i've wanted to go for, not quite cafe,but speedy lookin'. I've got much lower and narrower bars on there now(still waiting on my new bar-end mirrors and turn signals)and i'm considering other stuff to do. One thing that gets me constantly is peg/foot clearance when i'm out having fun. I'm considering moving the pegs up and back a bit using a waterblasted or cut piece of plate that would use the already exsisting peg mount style on the '78(the one bolt, and frame support), but also using the larger horizontal swing arm frame tube that's a bit up and back from the current mount to brace a relocation plate. This in theory should allow for that single mounting bolt to still hold. After that my choice of aftermarket pegs and setups are much higher, but so is my ground clearance! I don't think the move would be so much that it would require a funky, multi-linkage shifter, but instead one that is just properly bent or fabricated. I'm sure the break lever could also easly be modified for this.
Has anyone tried this before? Sometimes i'm not sure if i'm talking gibberish and no one gets what i'm saying or not. But yeah, it would be giving the bike more of a sportbike riding position, and a lot more peg/ground clearance.
NOW WITH ADDED, PROBABLY NOT AT ALL HELPFUL GRAPHIC MADE IN MSPAINT!
Sorry for the horrific quality.
Imagine the red filled in area is the stock 78 peg bracket(the round circle on the bottom being the peg, and the round circle on top the mounting bolt), and this would give you an idea of the new position i was looking at. At that, it's a bit drastic, and i would probably move that down and forward about an inch. The bit part of the idea was using that swingarm tube(the external part, not the nut or anything)as a bracing area for the plate.
Another idea, this time i would use some sort of sportbike peg or non-drop style that just bolt on, represented by the red circle.
