Hi guys,
I am fed up with the weakness of the turbo oil inlet hose. I've replaced it multiple times over the last few years, and it keeps failing. ObviouslyI experimented with different types of hoses and insulation materials, as well as clamp types. I am not sure why this is. I suspect it has to do with the hot climate I live in (Israel) and the fact that my home is located at a peak of a mountain, and I use a lot of Turbo boost climbing it up, and then shutting off the engine while its extremely hot.
Anyways.. I noticed my wife's car keeps the radiator fan working after engine shut-off. It happens even when the coolant temp is well below the fan-on threshold. I am thinking that the ECU is smart enough to figure out that the turbo had been working hard just before the engine-shut-off, and thus it keeps the fan running in order to cool down the turbo itself (and the oil in and near it). I am thinking of building a similar mechanism for my CX500TC. It doesn't have to be fully automatic - but rather just a timer that I can manually kick-off on shut-down and it would keep the fan running for 30sec to 1min.
What do you guys think about it? does it make sense? has anyone tried something like that?
and besides that - do you all suffer from that oil inlet hose going bad, or is it just me?
Thanks,
Oded
Thanks,
Oded
