1 - 3 of 3 Posts
About to reinstall the rear cover on my triple bypass project and I'm checking the gear shifting as per the old triple bypass page on the wiki (which appears to be offline at the moment). The 5th gear position is not advancing all the way into the slot on the shift drum cam plate as it does on the other gears. Is this normal?
Auto part Automotive wheel system Wheel Engine Rim
Discussion Starter · #3 · (Edited)
Got it. A slight turn of the shaft dropped it into place and now it is shifting through properly. Thanks.
1 - 3 of 3 Posts
