while i was waiting for my brake pads i thought i would double check if i still had a coolant leak. i brought the bike to the center of the drive way and started it up. after 10 min. of running the tstat opened and yes sirie! coolant leaking in multiple locations. i tried to seal it up with the high temp silicone i got for this but it was still leaking. also when the cooling fan engages it draws enough power to stall the motor unless the rpms are up. still didn't stop me from wanting to take it for a spin. took it for a little test drive down the block and things were great there. until i pulled back into the driveway and all the burning coolant began to steam up on me. while i let it cool off i found a puddle of gas under the bike. i'm pouring fuel out of the left side overflow.
so from being 1 part away from being done i now have to pull the carbs and the radiator and cross over pipes back off. replace the fan with a smaller one, seal all the leaks and figure out why the damn left side float decided to stick.
