i had to drill out the screw that holds the tach cable in place down at the wheel. does anybody know what size of screw this is supposed to be? i looked through all the parts break downs and cannot find it.
Tach or speedo cable? Speedo cable at the wheel, tach cable to the front of the cam.
Both are probably the same screw but when you replace it do so with a hexed head bolt.
its the screw at the front wheel. the one for the tach came out fine. it was probably well lubricated due to the massive oil leak i had
