1 - 20 of 58 Posts
You know, that orrible powdery white stuff you get on neglected engines
I dont do pretty but hate to see a motor covered in rust and oxidisation
so before doing the internals I'm cleaning up the GL500 engine that was
given to me recently.
I still have to get in the nooks an crannies but its getting better
and less horrible to look at.
It much nicer to work on a clean engine anyway.
I suppose I'd better paint it or something to protect it from going crusty again
Is mine next on your list? Ok, mine isn't THAT bad, but still needs help.
11235813
Marmite ?!!
Dont be daft thats way too corrosive
(Not as bad as Vegemite of course, that stuff'd strip a lavatory bowl
Its illegal in civilised parts of the world y'know)
Just went round the local cheapo shop and bought some wire brush attachments
for a drill. Brassy coloured things and most of it comes off pretty easily
I'm down to nooks and bloody crannies now
and typically, in there the old paint is sticking like sh*t to a blanket.
Getting there......
BTW
213455........
BTSTGTFTS ?
Huh ?
WTF??
Ooh!
That does look nice Shep, wanna do mine?
I'm bored already
I'll probably go more for the rustic effect
aka the lazy cheap bastard look
BTSTGTFTS ?
Huh ?
WTF??
Ooh!
I'm bored already
Been There.Seen That.Got The Effing T-Shirt
PS
That paint is the best paint ever for bodging.Drys really fast.Blends like no other paint for touch ups.Covers a multitude of sins and covers without primer
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9254126&fh_location=//catalog01/en_GB/categories%3C{9372013}/categories%3C{9372030}/categories%3C{9372123}/specificationsProductType=radiator_paint
Oh right !
I was just going ask about primer
that rad paint was mentioned to me and so was etch primer
How has it it fared sans primer?
I might nip up B&Q later and get a can
does it come in a range of attractive colours?
I have used Dupli-Color Engine Block Enamel, High Temp to touch up my radiator...No problems, no primer, little prep, minor sanding, wiped down with thinner, and sprayed. Also picked up a can of Dupli-Color silver, (looks like our motors) equivalent to a bead blasted finish.
BTW
213455........
Very good Reg... I knew somebody would get it eventually. Lots of clever blokes around here. Did I use "blokes" properly?
1.61803399
Since Shep reared his I'll rear mine
I used the "Duplicolor".......been 6 months now....have ridden it in the HOT 90 degree heat many times...so far no cracks, peels, chips and it still looks as good as it did when I got done painting it.
I touched up the "Honda" logos nameplates on each side with a "Sharpie"...no problems with those either.
Good luck Reg.....as you know the successful paint job is all in the prep work !
Oh right !
I was only ever interested in the Satin Chrome finish Reg.It lasts for years and is easy to over spray when required as a touch-up and needs no primer.
Discussion Starter · #20 ·
I'll go for that satin chrome too then
looks plenty good enough for me
'attractive colours' was me being somewhat facetious as usual
although I did wonder about a satin black but it isnt important
as basically, I just want to protect the alloy from oxidising.
1 - 20 of 58 Posts
