I picked up some saddlebags and one was involved in a fall or something was dropped on it. I can tell that the top has fiberglass since it's exposed. There isn't really a hole but a soft spot about the size of a dime where it looks white. The saddlebag is kind of odd since it isn't the normal shell that i'm use to. It is hollow welded two piece design. The inner or bottom shell almost touches the top shell with there being maybe a 1/4 inch gap between the top and the bottom. But the border all the way around has a 1x1 hollow section and the absolute front has a 1x2 inch hollow section and that's where the damage is. There's maybe 4 inches of cracked paint. Under the cracked paint the fibers are holding but you can tell it's damaged.
So what works to fix this fun? I almost wish I could fill the hollow gap with something hard or would get hard so I could focus more on fixing the area then wondering how to reinforce it. I don't really think it will ever be put in a high stress situation since it is on the top outside corner but I want to get it fixed in case an act of god happens.
