1 - 9 of 9 Posts
Hello everyone,
I have been stuck on this problem for a week now and have found absolutely nothing that is improving the issue. I cannot get my bike to run properly at all
My Right Cylinder:
Oval Pod Filter
90/120 Jets
2 1/2 Turn Fuel/Air Mix Screw
Running Strong
Strong Vacuum (bottle manometer)
Black Spark Plug
My Left Cylinder:
Oval Pod Filter
90/120 Jes
Inconsistent Running, Weak, Backfiring
Weak Vacuum (bottle manometer)
Clean Spark Plug
I have replaced the seals and the intake manifolds which were cracked and damaged, no fix
I swapped over the coils, no fix
I bought a different CDI unit, no fix
I have tried adjusting the balancing screw between the carbs, little to no difference, right cylinder still much higher vacuum regardless if the screw is all in/all out.
This is causing me an enormous headache, does anyone know what might be going on here???
Air leaks??? The carbs are out of sync, air leaks or
ACV failure, just a guess. Check the boot from the
carb to the cylinder head and the O ring.
Carb linkage not properly installed opening
carbs unevenly??????
Have you checked compression or done a leak down test? What is the history of the problem; what changes did you make to the bike before the problem started?
Discussion Starter #7
Thanks for all the responses guys, I will try and answer all of the questions.
There are no air leaks, I have tried the wd40/carb cleaner tests and everything is tight and sealed
I have swapped the plugs
I haven't checked compression or done a leak down test
As the bike was bought as a barn find/unfinished project I cannot assess what caused the change
I am going to send off the carbs for ultrasonic cleaning and see what comes of it.
Discussion Starter #9
Not necessarily, but it was on the list of things to do anyway. Two birds one stone and all..
Brilliant suggestion. I have stripped the carbs down and found that the left hand one has a small (pin sized) hole in it, no o-ring and no spring.
May be the cause
1 - 9 of 9 Posts
