Hello all! First post... Just wanted to say thanks for being here
ok so my 81 cx500 deluxe has some running light issues. Blinkers work, but i am replacing the blinker switch assembly because the left side works fine, but the right you have to really push on it to get it to work. Sometimes when you turn the blinkers off, the left front will stay on, but if i wiggle the switch it goes off.
have tank and seat off and headlight out. Cleaned the grounds and went over all the wiring, looks good except the flasher has to prongs, and 3 wires. The one is disconnected:
And in the headlight there are two wires not being used, one is a light green, with a large double female end. The green is a lighter shade then the ground wire. The other is a pair of brown wires that share a single female end (smaller). They obviously don't plug in together, lol... maybe an option for something on a custom?
Don't really know at this point. The taillight is on constant and works. Checked and replaced all the blinker bulbs. And if the switch doesn't fix it, and i can't find the problem is there some other way I can make it all work? Tried attaching power to the light from the battery, and it works great, just it won't let the blinker flash...
Any help is appreciated! Thank You,
-John
-John
