I just purchased a 79 custom and I noticed that the running lights are not working. Both front a rear blinkers are working, but no running light. I checked the grounds and they look good. I check the bulbs and they look good. Unfortunately that is the extent of my electrical knowledge. Any advise would be helpful. Thanks.
Hi mate, where in the world are you? It makes a difference. You may or may not have a light switch.
Also, please define 'running lights' .
I think I've just twigged. You mean the ones in the front indicators and you're in the US?
Put this info [bike, location] in your profile. It makes it simpler.
You should be aware that you'll only have running lights in front, via dual-filament bulbs. Did you verify that the bulbs in the front turn signal sockets are dual-filament? Also, check in the fuse box (under the square cover at the center of the handlebars) and make sure there are two 10-amp fuses in place. The lower one is for the running lights.
Checking the fuses is a good idea, but with a 2 fuse + main system he should be missing a couple of othe electrical items shared on the same fuse.
Are you certain they're not single filament aftermarket replacements or simply rear ones?
Discussion Starter #5
Thank you. I didn't know that the light would only be on in the front. You just cut my work in half. I confirmed that the bulbs are dual-filament. I will check the fuse. I assumed that the signal light and runner would be on the same fuse, so I didn't think to check. Thanks.
