1 - 8 of 8 Posts
So I was finally able to get the bike running after cleaning the carbs 3 times.. Now it seems to be backfiring through the exhaust! Fire is also coming out the exhaust pipe when I pull the throttle back with load popping.. I pulled the spark plugs and found the right side was wet with black oil. cleaned and re-gaped the spark plugs.. still popping and backfiring with flames. Pulled the plugs out again no oil. I am pretty stumped on what to do at this point. I've even tried messing with the needle valves but to no luck. any help would be appreciated!
Discussion Starter #6
I Talked to my local Honda cycle center and the gentlemen there said that because I do not have an air box on and only pods it seems that I am running to lean and need to re-jet the carbs. What number jets do I need for this bike?
The air cut off can cause poor idle and a very rich mixture.
if the carb is working right with pods and the small jets it should be lean --- you are saying its way too rich. The air cut off valve is to prevent popping of exhaust.
honda put it there customer confidence.(a smooth exhaust note)when 1 goes bad on my bike i block and leave it that way.
you can test for a bad cut off by blocking the air orifice with a piece of rubber if you leave it blocked it will/may pop
get the carbs right before rejet
My 2 cents
1 - 8 of 8 Posts
