Hi everyone,
Now that my carbs are performing fantastically, thanks to various folks on here and a week of patient step-by-step following of instructions, I'm ready to tackle my machine's OTHER major problem.
Ever since I've had it, it has always run on the edge of the Red Zone. Under load it would go past to the H. Not smart, yes I know, but I had tried everything I knew and really wanted to drive it.
I'm starting to suspect crystallized coolant after reading several posts, so I want to be sure I have the procedure correct.
I plan to:
* Drain and remove the radiator
* Drain the engine coolant via plugs on the front of the engine, that is, IF anything comes out.
* Remove the thermostat
* Put system back together and fill with 100% white vinegar
* Run the machine until it is well in the Normal zone
* Shut it off and let it sit overnight
* Drain and check for crud
* Repeat until no more crud reveals itself on draining
* After it drains crud-free, replace thermostat & re-fill with new 50/50 mix.
Is that about right?
I plan to:
