As suggested I tried to hook up a compression tester today, but that ended in failure, didn't have the right adapter to get in there, likewise the valve setting, somebody snapped off the thin feeler gauge blades of my dads.
I've noticed also that the bike is now running quite a bit warmer, stays right on the space between the thin and fat white lines normally, but now I've noticed after running highway speeds then sitting at idle in a line that it crept and stayed about halfway up the fat band, I'm concerned about it overheating or doing something nasty before I get it to California, I'll be in Vancouver another two weeks so I might have a go at borrowing tools or something or worst case taking it to a shop to have a quick look see.
I am suspecting a lean situation or a head gasket even more strongly now, the left hand pipe has some bronzing and a bit of blue on the inside of the curve of the pipe nearest the exhaust port on the motor, it does sometimes still feel warmer to the touch than the right. Is there any easy fix to keep it going until I get to bring it to LRCX.
I have tracked down a tapping noise a bit more that I was worried about, it goes away when I pull the clutch in, I'm now hopeful it's something wrong with my clutch rather than the motor/transmission. Is this something that is likely to wear out soon?
My coolant level is slightly down from full, and has a little bit of brown oil froth floating on the surface, maybe 2 small patches a few cm in diameter each. It doesn't really seem to be increasing, what could cause this?
