1 - 18 of 18 Posts
OK, so I have a 2-1 MAC exhaust and I believe 1980 carbs on my 1980 engine, which is in my 1979 CX500C. When I start the bike up it seems to purr right away, but after I run the throttle on the road and decelerate, I find the engine still running high rpms. Along with this there is considerable sputter noises around 4 - 5 grand. I'm led to believe this is jetting/mix screw stuff, but just wondering if it could be because of the MAC system running on stock carbs and this is "normal".
The carbs have not been deep cleaned or redone, the engine makes a nice little tapping noise as well, so clearly more than one gremlin at play on this ride.
Which direction do I run first?
I;d do a quick visual
stand by the bike and open the throttle then release the grip while watching
the mechanism at the carbs
you should see it snap shut quickly
If it doesnt I'd suspect the cable.
Ditto what Reg says. It may be the vacuum slides are hanging up a bit too. I think you can remove their covers and clean them without removing the carbs. Don't oil them tho, that just attracts dirt. Usually just a good polish is all they need. Some have tried graphite, I have not, but a little probably wouldn't hurt anything.
Yeah, what he said
When I assembled my carbs I was lucky in that I had a choice of pistons/slides
and used very good ones.
I've seen some which had obvously been chafing the carb body and had some heavy
scoring.
you usually find it on the side nearest the manifold and I assume its due to the incoming air
pushing the piston against the body.
This plus any oily crud could make them sticky and slow to sit back down
when you close the throttle.
I'd wager you have air leaks at your carb/intake connections. Had the same issue on my 650 last year.
did you rejet your carbs? be sure to check your plugs for the mixture! I had a super lean mixture in another bike once it kept running even after i pulled a plugwire it was dieseling and it destroyed my crank my rods and the jug and piston so... it was destroyed worthless... make sure your careful you dont want to be buying an engine
Thanks people. I'm hoping to work on her in a few short days. I'll let you know the outcome.
Funny you should ask. I just got around to tinkering the other day. I've had a bug going around my house and now I'm on horse pills!
So far I have tested the throttle response while turning the bars, doesn't seem to have any effect.
I did notice that once the engine got warm the revs tended to stay up more frequently.
The rubber boots (mainly from carbs to engine) look a little dry rotted.
I definately have air displacement going on from my header region.
Couldn't check the slides as the boots to the air box are still on. By still on I of course mean after wrestling to get them back on. I really, really, REALLY hate to take them back off. I know I'll have to, but man, do I have to?
I'm also checking my push cable. If the motors stays reved, shouldn't pushing the throttle back stop them? Mine is not, so I'm thinking this is a bad thing.
Those boots to the airbox shouldn't be that hard to remove and install. I take the intake side loose first, using a screwdriver to pry off the rubber, after I have rotated the intakes in toward the center of the engine. This should give you about a half inch of free space. Then the carbs easily slide out of the airbox connectors. Wiggle the carbs out the left side of the engine, and then detach the choke and throttle cables.
After a couple of times, you should be in the 15-20 minute time range for taking off the carbs.
Well, the taking out, putting in part I'm actually getting good at. It is the liking it part that I still have to master! So you're telling me I actually have to take the carbs out again, not just look at them while the bike is running. Man, this must be why people love these bikes so much.
Discussion Starter · #14 ·
Don't take the Airbox side boots off unless absolutely necessary!They are a PITA to get back on
That's what I'm talkin' about! It took me two days to get those things back on! One day of cursing and knicking knuckles, and a second day of using my head and a hair dryer to make them more plyable.
While running, spray some carb cleaner around all 6 intake connections. @ airbox, @carb to intake, @ intake to head. Any change in RPM and you can pin the air leak down as the issue, and pinpoint the spot of trouble.
Discussion Starter · #16 ·
That makes sense.
What about the push cable? Is it not functioning properly, or can't I tell from this?
I had a set of carbs that would not let the engin idle down well and found that the mid-jets had to be replaced.
cx500c 81
Discussion Starter · #18 ·
cx500c 81
Thanks, I'll look into that too.
I just took a look at the cables, they seem to be doing there thing, however, , ,
After forcing the throttle closed a little too rough, I sent the rpms down to 1000, 750, stall. I think I may have stretched the cable/fitting or something, so that's not good. Looks like I'll just have to bite the bullet and take the carbs out, check out the slides, cables, and boots, and start from square one. What a piss, and I just got it on the road too, damn it!
So to recap:
cables not binding
push/pull working as expected
next step, removal of carbs.
1 - 18 of 18 Posts
