Have been doing a lot of search and work on the carbs. I have a right cylinder that is running rich, and lags at idle. The engine seems to work to idle at 1500 rpm after some adjustment, but its running on one and the right cylinder loads up. Oh if I shut off the petcock while running, the idle smooths out, the dead cylinder fires nicely, and it will idle like a sewing machine. Very frustrating.
I have checked the float height, and set it. I went to high as now I have starvation at 70 mph, surges a little.
But always idles somewhat poorly, right cylinder is definitely the culprit. I have cleaned the carbs, set the pilots to 1.25 turn out, and worked with the float heights. I had them set right at one point, but the poor idle always happens.
Tonight, I did the poor mans synch, pulled the left plug cover, and it struggles to start, and tries to idle at 750 rpm and dies off.
The right plug cover pulled (to let the left cylinder fire. The bike actually idles at 1500 rpm, and idles nicely on the one cylinder.
Synch it (after I reset the floats, again)? If so which way do I turn the screw to adjust.
My concern is the fact that ever since I rebuilt the petcock, it has done this. Did I damage the diaphragm? It acts as it should, no fuel shall pass unless the vacuum is operating (bike running, but it does shut off too.
Its is really wet if I let it idle in the right cylinder, and my mpg STINKS. went through 2.0 gallons of gas in 30 miles.
Help please?
Help please?
