1 - 9 of 9 Posts
My 79 cx500 is only firing on the left cylinder. The right is getting spark and the carb is getting fuel. I rented a compression tester to see if that is the issue but they don't have a small enough adapter to test my bike. Any ideas what I should look for or what might be causing this?
Well, 1st off what is making you think its not firing on that side? Are you going by exhaust pulses? Do you still have your hbox on or not. My bike has the hbox removed and when I first got it I noticed there wasnt much coming out of my right pipe, I feared the worst like you. Checked and was getting spark, then it kinda became off and on (not riding it, just tinkering) someone had mentioned it may not be getting fuel. So my carbs are off right now being cleaned and they were pretty nasty. Not positive thats my problem yet, but very certain. You could get a spray bottle with gas and squirt thru that carb then fire it up and see how it does
Well, with the hbox on you wont be able to tell by the exhaust. But you could.still squirt gas is there and see if it temporarily sounds better. Did this happen all of a sudden?
1 - 9 of 9 Posts
