1 - 13 of 13 Posts
Ok, so with all these topics of people getting hit and hurt I have decided to try something out. I think I am going to take my helmet and paint it with retro-reflective paint. I think I have found a supplier that can provide the beads and I am going to see how well the stock paint reflects since I am getting some to touch up my gas tank. Heck... if things go well I might see what I can do to my bike to make it more visible. Now I know there is tape and stuff, but I like paint better... So call me crazy and call me posting in the wrong section but hey! you only live once and why not make it so you can go to court and say 'there is no way in he** that they did not see me.'
It will take me a bit of time to get things set up but I hope all goes well!
There is no doubt that florescent colors get peoples attention... Hwy workers all wear orange vests, some hunters do. If it wakes up only one SOB before they run over you, maybe it's worth it.
I'd just be carefull that whatever paint you use, it does not act like a solvent instead of a coating
compromising the Helmet surface might not be a good thing.
EDIT: OK, you are nuts
and this is posted in the wrong place....
Seriously... you are not crazy, and it is a "modification" to your CX. So to heck with the interweb polize
Maybe some LEDs along with the reflective paint. I'm thinking of a strobe light on top of my helmet and adding air horns... yes, you may call me "CRAZY"
Well first off water based paint is the only thing touching my helmet. It seems to have the least risk of damaging the helmet. Second... In researching reflective and retro-reflective markings, I have found an interesting study done by the NFPA regarding reflective chevrons on the back of emergency vehicles. that if the chevrons face down, it can cause drives to drive into the apparatus where chevrons facing up will "push" drivers away. So... the last thing I want to do is turn myself into a target.
This will take more research before I continue.
(ill try to find the study again if anyone is interested... I forgot to save it)
Had em over here for years
And we still think you guys look funny over there. We are now joining the club with the striping.
yes i would like to read up on that zegwin so when you have the time go ahead and email it to me if you dont mind
thanks
So far all I can find is the NFPA standard that requires the chevron striping. I'll ask my fire chief if he knows where I can find the report regarding the chevron striping on Thursday. This is really annoying me that I can't find it again.
(the NFPA standard is 1901)
"REFLECTIVE REQUIREMENTS FOR THE REAR OF THE VEHICLE
15.9.3.2 At least 50 percent of the rear-facing vertical surfaces, visible from the rear of the apparatus, excluding any pump panel areas not covered by a door, shall be equipped with retroreflective striping in a chevron pattern sloping downward and away from the centerline of the vehicle at an angle of 45 degrees.
15.9.3.2.1 Each stripe in the chevron shall be a single color alternating between red and yellow.
15.9.3.2.2 Each stripe shall be 6 in. (150 mm) in width.
15.9.3.3 All retroreflective materials required by 15.9.3.1 and 15.9.3.2 shall conform to the requirements of ASTM D 4956, Standard Specification for Retroreflective Sheeting for Traffic Control, Section 6.1.1 for Type I Sheeting.
15.9.3.3.1 All retroreflective materials used to satisfy the requirements of 15.9.3.1 that are colors not listed in ASTM D 4956, Section 6.1.1, shall have a minimum coefficient of retroreflection of 10 with observation angle of 0.2 degrees and entrance angle of −4 degrees.
15.9.3.3.3 Any printed or processed retroreflective film construction used to meet the requirements of 15.9.3.1 and 15.9.3.2 shall conform to the standards required of an integral colored film as specified in ASTM D 4956, Section 6.1.1."
Here's the requirement but it does not mention the car crashes obviously. Ill keep hunting though!
http://mutcd.fhwa.dot.gov/pdfs/2009/pdf_index.htm
This might have a little more info. Honestly wearing a reflective vest or a flashing light may be best, it attracts attention but doesn't make you a target. That's really all you want is to have the driver see that flash from the striping on the vest when we are working outside, not be so distracted by the abnormal site that they atually stare at it and run into you. My helmet has a flashing LED light on the back, and at work when we are on the highway we wear the new 3M retro-reflective material. It seems to be the most visible IMO.
I use a lot of reflective pinstriping tape on my sidecar rig and have a large cross shape done in 1" refelctive tape on the back of my helmet.
The cager who cut me off and ran me down said what they all say "I didn't see you". I am quite certain that had I covered my GL in strobe lights and been wearing a yellow tutu, a beanie hat with a propeller and firing off Roman candles she would still have not seen me and run me down.
I have personally witnessed a gal T-Bone a fire engine that had ALL it's lights, sirens and horns firing off at an intersection. Her traffic light changed to green and she ran right into the side of the fire truck.
When they don't see you, they don't see you. Ride accordingly.
· Premium Member
I've added retro-reflective tape to my helmet (though I still need to add a little more.) I'll try to get some pics this weekend, if I can remember.
I was inspired by a forum thread from earlier in the summer discussing retro-reflective paints, but I can seem to find it, even with a search. Does anyone remember that?
R
I think the reflective clear coat for helmets would be awesome because it's the highest item on a bike should be seen from all directions, vests sit lower and thus are only seen from back and side and if you have a rack and box maybe only side helmets with refective coat would rock
1 - 13 of 13 Posts
