Story time!
Decided to do something about the mechanical seal on my bike. Dropped the engine, opened her up, extracted the old seals...
Couldn't find a replacement rear cover gasket. Bad timing, I suppose.
Not to be discouraged, I decided to check a few other things while waiting for a listing. Snapped a couple bolts while replacing the clutch cover. Cried. Still couldn't find a gasket.
Winter... came (California winter). Put everything away for about 8 months. Cried a bit. Acquired a new bike in the meantime ('08 Ninja 250 that I hate working on...).
Finally located a gasket and bolts. Pulled everything together over the past month, alternating between sitting on my butt waiting for parts and completely neglecting my personal health to get everything back together.
Engine is back in the frame. New stator, new seals, new gaskets, Rae San Pickup (not new; did that a few years ago). Fluids replaced. Carbs are doing their jobs. Compression is good. Timings adjusted.
No spark, either side. Tried searching for help; Motofaction seems to be a dead end, Haynes manual is mostly irrelevant with the new pickups, forum threads all seem to be about CDI bikes and/or replacing the ignition coils with 'Ignitech' pieces. Mine is TI and I'm using the stock coils.
I've stuck a multimeter in various places, checking for continuity and resistances in logical places; everything seems to be wired up correctly. Obviously not, though. Shutoff switch is working correctly, and yes, I do have it turned on.
I'm probably missing something obvious here. Or I just need to sleep on it. Possibly both.
Any help and advice will be appreciated; I'm at my wit's end here...
Thanks in advance,
Sam
Thanks in advance,
Sam
