Thanks for the input and the interesting pictures. What I was after though, has anyone tried to successfully install a non CX500 or even GL500 radiator. If they did and it worked, what did they use?
I had a radiator for the 78 CX500 Resurrection, but after I cleaned it using vinegar, I didn't exactly perform any leak testing. Upon installing and filling it with coolant, found it leaks pretty bad. So, I did perform a bubble leak test to find out where the leaks were and then see if I can solder them.
I capped the inlet and outlet and then used 5-10 PSI air to find the leaks. I was able to solder some of the leaks, but one in particular did not work out. The brass kept fragmenting. So, I did have an extra GL500 Radiator that I installed temporarily to make some start and run test.
It was a pain getting the top coolant line mounted, but so far it is not leaking. I did find a used 78 radiator for sale at an acceptable price on EBAY and bought it. I will be cleaning and leak testing it next weekend. But these are all old radiators. If you know of anyone having successfully using a radiator off a different bike, let me know.
