1 - 17 of 17 Posts
Hit up AutoZone, they sell several that are about the same size as the OEM horn, and are advertised as being louder.
My horn wasn't working and after some tapping with a plastic hammer, WD40, and adjusting the pitch screw it started working again.
i'll give that a shot...
JC WHITNEY HAS A HORN THAT WILL FIT FOR ABOUT $12-13... MUCH LOUDER THAN THE STOCK HORN... SAME BOLT PATTERN
thanks. do you happen to know the code/product #?
'82 GL500 '83 GL650 '21 RoyalEnfield INT650
I got three replacement horns from Sidecar Bob. Thanks Bob! They all work! The "least pretty" is the right pitch.
Reading above:
Can I change the tone with the little screw on the back to get harmonics? If so, I can choose a shineyer horn.
Thanks!
the Stebels featured in the early thread look good-some more compact than others
Many of the original "twin horns" of machines of this era were pretty good....others resembled a bird squawk
My opinion is the louder the better for sure!
Depending on the condition if the parts inside the horn you may be able to tweak the tone a bit but I've had them stop working instead in the past so it can be a bit of a gamble, although if that kills it it probably didn't have a lot of time left anyway.
FWIW, I used to worry about how the horn sounded but over the years I find I use it less and less so anything that works and isn't particularly ugly is OK with me so I run a single 99 dB horn on each of my bikes (I believe they are approx. equal to the original high tone), bought cheap when I found them on sale somewhere. Ironically, I bought several of these because, while the one on the GoldWing was pretty old, I had been going through about one per year on Eccles (it can get pretty salty) and didn't expect these to last either but I think these ones are about 5 or 6 years old now ;-)
Maybe I should play with my dead one first, then I have spares too. And I can probably shine up the one that is the right pitch. You are right, function is what matters. The 650's horns sound as good as the 500s now.
I can't remember how they looked but if it is just grimy you should be able to wipe it off with a rag dipped in mineral spirits and if rusty you can gently sand it and give it a couple of light coats of black spray paint and it will probably look OK.
The Black is okay. I used aluminum foil on the chrome and steel wool . Maybe I'll try sandpaper. But it is fine for now. Happy to have a horn that you can hear!
Okay, Zinc! The shiny outer ring. Thanks!
Lee
1 - 17 of 17 Posts
