I recently purchased my first motorcycle, a 1980 Honda cx500c that had been sitting for two years. Now I've never really worked on anything mechanical until now but I changed the oil, cleaned air filter, took carb out and apart and replaced gaskets and float needles and cleaned jets and bike would start fine but was pouring gas from right carb still. Took it apart again and this time replace o rings on fuel transfer pipe and air cut off valves while I was at it as well as replace drain screw o rings and once I switched petcock from off to on it wasn't leaking anymore, then I started it up and it started leaking fairly heavily from around gasket (which I had just replaced), I think I may have not seated it properly and cinched if the first time. Uncle rides harley and is president of a club and suggested I dab rtv on gasket and try to get as clean as possible then reattached bowl. Now I'm waiting for 24 hours for it to cure before I turn the petcock back on. I used high temp red rtv. If this doesn't work, what are my options? Can I find a cheap RH carb replacement somewhere? Or should I just say screw it and take the carbs to a shop to be redone completely? Also, if some terminology is wrong, please keep in mind I literally just learned all of this by watching videos and looking up diagrams lol
