hi all - I am cleaning my carbs and replacing very old, crusty parts. The screw right above the jet needle is totally stripped and I'm having a hard time getting it out. Any suggestions? This image is the screw I am talking about
The slot in that screw looks servicable. When you say stripped do you mean that the screw turns easily without coming out?The screw right above the jet needle is totally stripped and I'm having a hard time getting it out.
I'd be careful with that. All the twisting force will be in shear on the small tab of the plastic "black banana."do you have a drill press ? If so , set the carb body in the vice - pre-soak the brass screw with penetrant of your choice , fit a suitable sized blade screw driver into the chuck on your drill , lower the quill until you have firm contact in the brass slot , then turn the chuck by hand , in the appropriate direction whilst holding firm pressure down on the screw driver. Wiggle the drill chuck back and forth to get some movement going and help the penetrant soak in .
Works for me "most times"
