1 - 16 of 16 Posts
Is there any tricks when you don't have the honda tool?
yes,its quite easy.
the fan is a tapered fit onto the shaft.
remove the bolt that secures the fan,and buy a bolt size...... Fan puller bolt.
M14 x 1.5 about 2 inches long
screw this into the fan until it bottoms out[touches the shaft] tighten a fraction more and give the head a tap.your fan should pop off
Go buy the bolt, Just a buck or two and you can easily find them at Lowes or Home Depot with the specs provided. That way your not pulling the wheels off. I bought a bolt when my fan imploded taking everything with it a couple of years ago. Worked like a champ.
The bolt is always better and easier to use without dropping the front wheel. Some Axles don't have the right thread on the front to do the job anyway.
If you have an air chuck, you can use that, works great. Might have to use a bolt or washers for it to reach, I don't remember if I needed them or not.
Now that's nice.
how do you get fan off if treads are strip????
A ball joint removal tool (pickle fork) works well too, BTDT many times. They're cheap (less than $10), and now most of the larger autoparts chains will loan you one for free.
Tap it in under the boss slow and steady and the fan will pop right off.
Could not find 14mm x 1.5 locally (Lowes, Home Depot, Ace, Rural King, Fastenal) I did find out that for many years, say, ’92 through ’08 Mercedes used a lug bolt that will work. So I went to the junkyard. The bolts were gone from the Mercedes but I noticed lug bolts screwed into a Volvo wheel and pulled one on a hunch. Worked fine, free. No idea what year Volvo but if you find a correct sized one on ebay the auction might list the years it fits. Same for the Mercedes. Searching eBay, it appears that a number of makes used the 14mm x1.5mm lug bolt. BTW, the threads need to go into the fan just under ½ inch on my ’81 GL500.
1 - 16 of 16 Posts
