1 - 9 of 9 Posts
i thought the fan would come right off but alas no. is there a way to take it off with out expensive tools?
a 14 x 1.5 metric bolt about 2 inches long.
im tearing apart the motor piece by piece, rebuilding and repainting every part i can. i didn't really want to go this far but, to properly strip and repaint the way i want its got to come all apart. plus i know what ill be starting with. a 30 year old bike and i dont know the history, new is better then guessing.
thread through the hole and tighten til it pops loose?
YUP........
Be sure to check the fan blades for cracks/fatigue etc as they are known to explode while riding.....
All The Best.........keith.......
You may want to consider the electric fan conversion while you have the thing taken apart.
The front or rear axle work.
If you´re lucky, that is.
The fan hub is made from rather soft metal. The axle has a chamfered / coned end. A flat-end bolt is much better. Every piece of thread is cruical. The fan axle advice is given in "Haynes´ Book Of Lies". I´ve stripped one fan hub, myself. Know several more...
If you´re going to use the axle - thread it in as far as possible. Tighten only softly. Tap (the axle) with a small hammer, at the same time you try to tighten a little more. Easy does it! Don´t get brutal!
Sture
+1 to the not the axles. It is a lot cheaper to go to the hardware store and buy the 14MM 1.5 pitch metric flat end bolt for a few bucks than risk an axle. I'd say only in an emergency, and even then.....would you have the tools at hand?
Joel in the Couve
1 - 9 of 9 Posts
