1 - 7 of 7 Posts
Hey everyone,
I have a 1981 cx500c that isn't quite starting. It ran when i first got it but my carbs were flooding due to bad float. while my carb is out, i was thinking of removing the Airbox to give it that sleek look with nothing underneath the seat. I read in places that i might have to readjust my carbs, if so does that mean just to resnyc them? I would like to know if i would need to do anything of that nature before ripping out!
Thanks for the help,
-DreamRide
You'll get plenty of others chiming in, but if you remove the airbox, you will need to fit some type of air filters (many use pod style), change the jets in the carbs (not the same as a sync), and fit a different breather vent from the crankcase. You will not likely see an improvement in performance, more likely a reduced performance. While the box may seem unsightly, it is a well designed part of the fuel and air flow system.
Get it running properly as is before you start modifying anything or you'll be chasing your tail for weeks.
To run without airbox you will need to rejet and likely mod a set of cheapo chinese pods.
If you can afford it, chuck the stock carbs and by a set of Mikunis from Murray. His set up works slick, fits well, and comes with everything you need. It changes the way the bike runs immensely.
Theres the answer i was looking for, thanks guys basically i shouldn't get the twin filters unless I'm willing to reject my carbs?
unless your carbs are properly clean they wont function correctly , so do as CXPhreak suggests and get the thing running properly before you start to alter anything . If you do remove the airbox - a sawzall is the easiest way to get it out - you will most likely need to rejet. Do a search of the forum for information on rejetting , and more importantly on the correct pods to fit. There are some pods that will block the atmosphere ports on the back of your carbs and prevent correct running. Read first , chop last
Reactions: nolimitz
+1 on read first, chop last. We don't need any more of those thread posts that says "Dammit, now you tell me! I just...........and it won't run"
1 - 7 of 7 Posts
