1 - 1 of 1 Posts
I disasembled and cleaned my petcock. The rubber and seals all looked good, but the o-ring was to big and it wouldn't go back into the groove correctly so I replaced it with a new o-ring of the same size as the groove. with 2 galons of gas in teh tank, the leaking is worse when it is on "fuel" not so bad on "reserve" and just slight on "off". Most of the leaking seems to be comming from between the plates.
Is there a common misstake I may have made or should I just fork out the $$ for a rebuild kit.
1 - 1 of 1 Posts
