This is a great forum and I'm glad I found it. Thanks for all the help I've found so far poking around and reading the past couple days. I'm fixing up an old 79' CX500 Custom I bought. When I put gas in it and opened the petcock, fuel started draining from the left carb. It's draining from where that copper colored tube that connects the carbs goes into the left carb. Obviously something wrong there. The carb gaskets also look old and dry and like they need some refreshing. Upon pulling the float bowl, I found one of the little rubber plugs in the carbs to be completely rotted to nothing. I'm guessing my best bet is to just buy a complete gasket kit that includes all of the rubber bits in the carbs.
Anyone know of a good place to get that kit for a good price? I'm OK buying a cheaper after market kit versus an OEM kit from Honda or something. Money is tight right now.
If you happen to know where to buy spark plug wires, that would be great too. The black plastic tube that goes into the cylinder head on the right side has cracked and completely broken apart.
Thanks.
Thanks.
